Activity Forums Adobe After Effects tutorial for BCC 6 color match?
  • tutorial for BCC 6 color match?
    Posted by Jon Iverson on July 10, 2009 at 12:45 pm
    Recently downloaded a demo of Boris Continuum Complete 6 for AE in order to try out the color match plug-in. This plug-in seems like it might be quite good in matching one video clip to another, but I can’t find any detailed instructions/ tutorials for it. The Boris site itself has some tutorials, but nothing for this particular plug-in.
    Any suggestions would be appreciated.
    Jon
    Michael Buie replied 14 years, 1 month ago 5 Members · 5 Replies
  • Curious Turtle
    July 10, 2009 at 8:42 pm
    There’s a Help button included on the top of every Boris plug-in control. Click on this and it will open up the appropriate help file for you in Acrobat Reader. The Boris guys generally write really good documentation.
    Hope that helps,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
    Need help with your planar tracking?: Rock Steady : Successful Motion Tracking in Mocha & After Effects & Tracked : The Art of Motion Tracking in Mocha for FCP
  • Jon Iverson
    July 11, 2009 at 11:27 am
    Thanks. I knew that, but all the information does is identify each of the buttons in the plug-in and doesn’t really explain how to use it in depth.
    Jon
  • Peter Mcauley
    July 15, 2009 at 4:52 pm
    Okay … perhaps I can be of assistance.
    The BCC Color Match filter was designed to match the color and luma values from a source clip (a) and a target clip (b). It solves the common problem where abutting clips of the same scene that were shot at different times of the day but need to look like they were shot within seconds of each other.
    The filter provides 3 point sample controls, from which the user samples regions from the highlight, midtone and shadow areas of the source and target (destination) clips. You start by applying the filter to the target clip and then disabling the filter so that it has no effect on the image. Then set the h/m/s samples for the source and target. Then enable the filter.
    A bias control was provided for the h-m and m-s regions, effectively enabling the user to instruct the filter on what values are to be considered highlight and shadow from the mid-tones of the image. To use this, set the appropriate view (h/m/s etc) and change the value in the h-m or m-s bias parameters, switching the view until you are satisfied with the region settings. Then set the view switch back to normal.
    At this stage you should be seeing that the source and target color and luma values are fairly closely matched.
    Finally, adjust the master level and color parameters to back-off or increase the master color and luma matching. If needed, this can be further tweaked using the individual h/m/s level and color parameter sliders.
    As with any color matching tool, it takes practice with the tool to really get comfortable with the controls. Once you use it a few times, I’m sure you’ll really start to see the benefit of having this in your toolbox.
    I hope this helps.
    Cheers,
    Peter.
  • Peter Tours
    August 9, 2011 at 6:40 pm
    Found this looking for BCC Color Match tutorial – I don’t understand at all. Does anyone know if there is a video tutorial? Thanks in advance!
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
    TRI EA5 1974-1977
    Convergence ECS1B 1977-1979
    Sony BVE 500 1979 – 1984
    Datatron Vanguard 1984 – 1993
    GVG VPE141 1993 – 1998
    Media 100 1995 – 2006
    Final Cut Pro 2005 to infinity and beyond!
  • Michael Buie
    August 19, 2012 at 12:43 pm
    I know this is an old post, but I thought I’d close the loop on the question about a video of this BCC Effect. It’s hard to find because of the title, but here ya go.
    Color Match in Sony Vegas Pro
    https://www.youtube.com/watch?v=jeaGqtnjwBA
    Be warned that the guy mis-speaks sometimes when he refers to “Source” and “Target”, but if you understand “Source” is the clip you are modifying (as he initially explaines) that you drop the effect onto … and that “Target” is the clip you want to makethe “Source” match to, you can overcome that glitch in his presentation.
    He also talked about BCC Levels Gamma effect, which I used to help my footage even more.
    Hope this helps.
