Activity Forums Blackmagic Design Tutorial : BMD Intensity Huffyuv capture with virtualdub
  • Anmol Mishra
    March 7, 2010 at 5:34 am
    I sent an inquiry to Dale who has this working, about colorspace issues..
    Here is the email..
    I was following your thread on virtualdub.org.
    I had a few questions as there were some issues.
    1. The build is a fork of virtualdub, and is only in the virtualdub-hdyc that squid_80 put out. Is that correct ?
    2. The version in the thread is the non Multithreaded huffy build. Is that right too ?
    3. Also, there were issues with the HDYC colorspace outputted by Huffy. The gent here did tests on a vectorscope and found some interesting things..Are you sure this is not occurring in the HDYC build you are using ??
    https://www.etfinder.net/capturepics/
    And the forum thread where this occurs..
    https://forums.virtualdub.org/index.php?act=ST&f=6&t=18348
    I do not have access to a vectorscope and my concern would be, that we are having small issues with colorspace using virtualdub and huffy that do not show up until the generated files are carefully observed..
  • Dale Mullins
    March 8, 2010 at 3:08 am
    Hello Anmol.
    I just responded to your post on the VirtulDub forums here:
    https://forums.virtualdub.org/index.php?act=ST&f=6&t=16116&st=32
    In summary, I do not notice any colorspace issues with my capture using the BlackMagic Intensity, VirtualDub and the Huffyuv compression. Details are in the link I posted above.
    Good luck,
    Dale
  • Anmol Mishra
    March 15, 2010 at 11:36 am
    We did a test posted at vimeo
    https://vimeo.com/10174263
    We played out a SMPTE color bar from a 5d Mark II. It was ingested with a BM Intensity card using Virtualdub. There were 2 files, a special Huffyuv build for HDYC and the default BM MJPEG. As you scroll through the video it can be seen that the colorspace changes when Huffyuv records. This is a confirmation of the problem first noticed at
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Anmol Mishra
    March 16, 2010 at 2:19 pm
    On further tests I decided to include the AMV2-MT codec from here..
    https://amamaman.hp.infoseek.co.jp/english/amv2_e.html
    Its a lossless 8-bit 4:2:2 codec similar to Huffy.
    It costs 10 bucks though.
    I found it to be the best lossless capture option. It gives 2-4 times compression in realtime. It seems to be a variant of the AMV codec, which is a variant of MJPEG.
    I will post a video that shows the colorspace issues with BM MJPEG, Huffy and AMV2-mt.
    AMV2-mt is a faithful reproduction of the SMPTE color bars..
