Activity Forums Adobe After Effects turtorial of this motion graphic (https://vimeo.com/102327078)
  • turtorial of this motion graphic (https://vimeo.com/102327078)
    Posted by Ed Home on October 17, 2014 at 10:57 am
    Hi everybody,
    The link attached beneath is the way my client likes to have it’s movie too. I mean the way of morphing and especially the way the lines animate.
    Does anybody know a good turtorial where the way of animating these lines are explained? Starting from 18 seconds, the way the tubes animate
    I hope somebody can help me….
    Thx
    Edith
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Jp Pelc replied 11 years, 10 months ago 5 Members · 6 Replies
  • Daniel Waldron
    October 17, 2014 at 12:58 pm
    You probably want to start by learning about shape layers.
  • Ed Home
    October 17, 2014 at 1:40 pm
    thx I will have a look at that
  • Tim Bentley
    October 18, 2014 at 1:41 pm
    This tutorial uses pretty much the same techniques though it’ll only get you some of the way there.
    https://lesterbanks.com/2013/03/animating-morphing-pictograms-in-after-effects-using-shape-layers/
    New film just added: https://timbentley.info/
  • Jason Jantzen
    October 18, 2014 at 7:48 pm
    Just a warning about using shape layers. Make sure you build them out of bezier shapes if you want to animate the paths. They still haven’t fixed the issue where the shape does a weird morph instead of animating after converting a parametric shape to bezier. Just check the “Bezier Path” box on the tool bar before making your shapes.
    Jason Jantzen
    vimeo.com/jasonj
  • Ed Home
    October 19, 2014 at 4:51 pm
    Guys, thank you all for the replies!!!!
    I’m gonna use your tips and info
  • Jp Pelc
    October 20, 2014 at 9:20 pm
    Looks like a lot of time animating shape layers
