Activity Forums Adobe After Effects Turning TV off effect?
  • Turning TV off effect?
    Posted by Rusty Bridges on September 28, 2005 at 11:50 pm
    How could i achieve the “turning the TV off” (you know, letter vanish, white dot in center) I really need advice on this. Is there a plugin that imitates this effect?
    thanks!
    Ogrus
    Shyguyjay18 replied 20 years, 11 months ago 7 Members · 6 Replies
  • Kenny101
    September 28, 2005 at 11:53 pm
    here’s something like what your looking for…the last part atleast
    https://www.ayatoweb.com/ae_tips_e/ae25_e.html#
    A newbie AE6.5 user 😉
  • Henry
    September 29, 2005 at 12:35 am
  • David Johnson
    September 29, 2005 at 12:58 am
    There are as many ways as there are types of TVs these days, but sounds like you want the the tube TV look. The easiest way is to:
    apply some RGB noise to a whitish solid
    animate the Y scale then X scale til left with a very small box/dot
    apply a glow with RGBish colors to the dot
    pre-render and apply it to your images with a tranfer mode (stencil maybe) or alpha matte
    I made the ones I use years ago so I may be forgetting something. Part of a good tube TV effect is what happens while the TV is still on so consider adding a bulge, scanlines and/or glare to your images before turning the TV off. A good sound effect can help too.
    I don’t know of a plugin that does the TV On/Off effect, but the Foundry Tinderbox 3 & DigiEffects Delirium sets have ones that can add some other TV effects like offset guns, vertical hold, ghosting, etc. As with most things plugins do, those can all be done with AE alone, but plugins are sometimes faster. Of course you could also record the same with a VCR and apply to your images with a transfer mode and/or opacity.
  • Roc Barbanica
    September 29, 2005 at 6:11 am
    Wht go through all that? Just shoot the tv when you turn it off.
    Shoot, as in with a camera!
    I’ve done it and it looks killer.
  • Chris Smith
    September 30, 2005 at 2:18 am
    Also check the archive because this is asked every month or so.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Shyguyjay18
    October 15, 2005 at 11:19 pm
    The final result quicktime looks very cool. This is exactly what I have been looking for. I can follow all of the steps with relative ease until that last one. Suddenly there are 8 unexplained layers with flashes, flares and keyframes galore. Is there an easier way to decipher what’s happening in the last step or should I abandon all hope? I’m still a relative newcomer to After Effects.
    Jay
