Activity Forums Apple Final Cut Pro Legacy Turning Sub Clips into Independent Master Clips
  • Turning Sub Clips into Independent Master Clips
    Posted by Chris Guevarra on July 21, 2010 at 12:33 am
    Hi Cows,
    Do any of you good folks know if there is a way to turn a subclip into it’s own master clip?
    The reason I ask is because I am getting the “Pre-Roll/Post-Roll” TC error when trying to recapture some corrupted clips by batch capturing and because I’m using the camera to capture (Panasonic DVX-100b) I don’t think it’s strong enough (like me) to start at the beginning of the tape where I’m assuming it was originally captured before I jumped on board with this project.
    Thanks cows!
    Chris Guevarra
    seekingasianfemale.com
    massmovementtv.blogspot.com
    Jeremy Garchow replied 16 years, 1 month ago 2 Members · 3 Replies
  • Jeremy Garchow
    July 21, 2010 at 1:38 am
    Just physically type in a new media start time in the browser that’s three or four seconds later.
  • Chris Guevarra
    July 21, 2010 at 6:02 pm
    Ahhhahaha! Woo, that worked like a charm! Thanks a bunch, Jeremy! You saved me so much time and work.
    That was such a simple (and obvious) solution but for some reason I didn’t think you could change the media start time in the browser. Thanks again for taking your time to answer such a noob question.
    Chris Guevarra
  • Jeremy Garchow
    July 21, 2010 at 6:21 pm
    When the clips are offline, you can.
