Activity Forums DaVinci Resolve Turning show mask on/off
  • Turning show mask on/off
    Posted by Ben Edwards on May 1, 2013 at 6:07 pm
    I must of pressed a key by accident and now rather than seing the footage I see a grey area showing where the mask is selected. How do I tun this off, google and manual have not helped.
    Ben
    Ben Edwards – Freelance Picture Editor
    https://www.funkytwig.com
    i5 550, Windows 7 / Mac Lion, Nvida 550 Ti, 8GB Mem
    Marc Wielage replied 7 years, 4 months ago 7 Members · 10 Replies
  • 10 Replies
  • Pepijn Klijs
    May 1, 2013 at 6:59 pm
    There’s a switch in the qualifier window and also a keyboard shortcut you can find in the view menu, from the top of my head… Command-H??? I use a panel so I kinda forgot…
    Editor/Colorist, Amsterdam, The Netherlands
    http://www.pepijnklijs.nl
  • Ben Edwards
    May 1, 2013 at 7:45 pm
    Tried lots of ky+H and no luck. What is the name for the toggle. It may not be called a mask, its the grey bit that shows what is selected in the qualifier/power window.
  • Pepijn Klijs
    May 1, 2013 at 7:59 pm
    Its called Highlight
  • Laco Gaal
    May 2, 2013 at 11:18 am
    Shift-H should do the trick
  • Marc Wielage
    April 6, 2019 at 4:32 am
    View -> Window Outline -> On.
    Make sure you have the Power Window pallet up, and choose the Power Window tool in the lower left corner of the Viewer on the Color page.
    There are pros and cons to using the Window Outline vs. Highlight, and in some cases one serves better than the other.
  • Félix Pg
    May 8, 2019 at 5:31 pm
    Thank you for your answer, I had been looking for this option for months to turn the Power Windows on and off, thank you, thank you! I take and I consult: you will know how to activate the Central Button in the Magic Mouse of Apple? I see that this option of the Central Button is used for several functions here in DaVinci. Or should I buy a mouse that has a physical Central Button?
  • Marc Wielage
    May 9, 2019 at 1:32 am
    [Félix Pg] “I see that this option of the Central Button is used for several functions here in DaVinci. Or should I buy a mouse that has a physical Central Button?”
    For me, the only way I can use Resolve is with a 3-button wired optical mouse.
  • Michael Gissing
    May 9, 2019 at 5:25 am
    I used to use a five button mouse but definitely get at least a three button mouse. So handy when grading
  • Eric Santiago
    May 10, 2019 at 3:51 pm
    [Marc Wielage] “For me, the only way I can use Resolve is with a 3-button wired optical mouse.”
    Marc, which one do you fancy?
    I had to retire my SGI mouse and tolerate the MS Intellimouse.
    I miss not having the scroll 🙁
  • Marc Wielage
    May 10, 2019 at 10:01 pm
    [Eric Santiago] “Marc, which one do you fancy? I had to retire my SGI mouse and tolerate the MS Intellimouse. I miss not having the scroll :(“
    I use the HP X500 Optical Wired Mouse, which is only $13 on Amazon. Works great with Resolve (at least for what I do).
