turning off audio in trimmer
Posted by Grzegorz Kwiatkowski on February 9, 2014 at 3:34 pmIs there any way to disable audio in trimmer?
Mike Ames replied 5 years, 11 months ago 5 Members · 10 Replies -
Steve Rhoden
February 9, 2014 at 3:49 pmIm not understanding you too clearly. When you right click on the
Trimmer window you can select video only or Audio only, so that when
you drag it to the timeline only that selection will be dragged.
Or you can right click and drag your selection and it will prompt
you as to what you want.
What exactly are you trying to achieve?Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-461-9019 -
Graham Bernard
February 9, 2014 at 7:56 pmDo you wish to Mute the Audio while you Preview the Media in the Trimmer?
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Steve Rhoden
February 10, 2014 at 2:54 pmI see. Trying to figure that one out.
Steve Rhoden
(Cow Leader)
1-876-461-9019 -
Graham Bernard
February 10, 2014 at 3:40 pmOK, using the “Dim” control I could lower to something like -12Db. This was a short stretch to lowering the DIM Internal Prefs Value from -12db down to -100db.
Using the K/S Ctrl+Shift+F12 it now “MUTES” the Trimmer using the k/s. If I was using this on a regular basis I’d be inclined to make a shorter k/s Combo. But there again, I really can’t think why I’d be wanting to do it in the first place?
Cheers
Grazie
Steve Rhoden
February 10, 2014 at 5:26 pmi see.
Steve Rhoden
(Cow Leader)
1-876-461-9019 -
Graham Bernard
February 10, 2014 at 5:29 pm[Steve Rhoden] “i see.”
You do? I don’t. I can’t see where I’d use it. Now if there is a purpose for it, I’ll listen real hard.
Grazie
Steve Rhoden
February 10, 2014 at 9:28 pmlol
Steve Rhoden
(Cow Leader)
1-876-461-9019 -
Aleksandra Królikowska
October 1, 2015 at 1:02 pmIt’s been a year, but I had the same problem today and found this simple solution. This doesn’t affect the audio of the clips on the timeline.
View>Mixer Preview Fader
And that’s it. Maybe it’ll help somebody.
