Activity Forums Apple Final Cut Pro Legacy turning down volume of MPEG2
  • turning down volume of MPEG2
    Posted by Eli Mavros on May 25, 2005 at 7:16 pm
    Is there a way to just adjust the volume level of an MPEG2 movie? I keep putting together these reels and sometimes a certain clip will be much louder than the others and what I normally do is recapture the clip from digibeta into FCP, bring the levels down, and then re-encode it. Is there a simpler way to do this? I have looked, but I don’t thing DVDSP gives you any audio level option.
    Thanks in advance,
    Eli
    Eli Mavros
    John Sutherland replied 21 years, 4 months ago 2 Members · 1 Reply
  • John Sutherland
    May 25, 2005 at 10:14 pm
    What I do in this situation is to find the .aif audio file associated with the clip, import into FCP, lower the level & rename (“ABC clip -8″), import into DVD SP, and switch it out in the track, Its quicker than recapturing and encoding, plus you can make several versions while you’re at it for testing in simulation mode.
    John Sutherland
    Quicksilver 867
    1.12 gb ram
    Atto UL3D w/firmware 1.6.4
    Huge 1.2TB Dual Max
    FCP 4.02
    CW 4.01
    OSX 10.2.6/QT 6.3
    Radeon 9000 w/2 17” crt monitors
