Activity › Forums › Adobe After Effects Expressions › Turning a specific effect on and off using a checkbox controller ?
  • Turning a specific effect on and off using a checkbox controller ?
    Posted by Lucas Piazzini on August 24, 2020 at 10:38 am
    Hi ! I know I can turn entire layers on and off with checkboxes, but to avoid having 36 adjustment layers, I wondered if there is any way control 1 effect visibility at a time, inside an adjustment layer containing multiple effects.
    Best regards
    Lucas Piazzini replied 6 years, 1 month ago 2 Members · 2 Replies
  • Filip Vandueren
    August 24, 2020 at 1:28 pm
    Every Effect has Compositing Options, which are only viewable in the timeline. (Because, Adobe reasons… it’s an effects setting, why on earth would they put that in the effects window :-/ )
    There you’ll find an effect opacity that can just as simply be controlled by a checkbox as a layer’s opacity.
    The effect might still take processing time when at 0 though, it’s just not “mixed in”
  • Lucas Piazzini
    August 25, 2020 at 6:14 pm
    Thank you so much ! Really nothing else to say than THANK, YOU.
