Activity Forums Apple Final Cut Pro Legacy Turn your DV deck into a data backup device! Cool stuff….
  • Turn your DV deck into a data backup device! Cool stuff….
    Posted by Bob Woodhead on July 21, 2005 at 11:35 pm
    Apparently this software’s been around for a few years, but someone on another forum just mentioned it. After I tried the demo, I’m convinced. in a nutshell, you can backup about 10-15GB per 60 minute DV tape. And it’ll span tapes! Media’s cheap. About 10GB/hr speed. And we already own the drive! https://coolatoola.com Seems like a winner for all of us in video….
    Bob Woodhead / Atlanta
    Quantel-Avid-FCP-3D-Crayola
    G5 DP 2G, 10.3.4, 3.5GB RAM, FCP 4.5, Aja IO, Huge 320R [raid3]
    Bryce Whiteside replied 21 years, 1 month ago 6 Members · 10 Replies
  • 10 Replies
  • Bret Williams
    July 21, 2005 at 11:37 pm
    The math seems right. DV is 5 minutes per gig, so that’s 12 gigs on a 60 min tape.
  • Rich Rubasch
    July 22, 2005 at 2:22 am
    But it’s real slow and considering that a tape is about $2-3 and a DVD disk at 4.7 gig is still around 70
  • Bret Williams
    July 22, 2005 at 3:56 am
    So true. AND you need their software. 2 DVDs burning at 8x vs. 1 tape running at 1x. You’re right. That’s completely a no brainer. Burn the DVDs.
  • Bob Woodhead
    July 22, 2005 at 12:11 pm
    Actually, I was looking at it mostly in terms of how to deal with archiving media from the upcoming P2 HD camera from Panny. It records HD onto flash cards, which you offload to HDD. So though the final edit would be laid to some HD tape VTR, what to do with the source selects? Too much for any current DVD (assuming some files might be larger than the media). But your points are taken about 8x burning. I wonder what that turns out to be, GB/hr? The software does allow random access of the material, though.
  • Daryl K davis
    July 22, 2005 at 4:24 pm
    How much data can be archived on a longer DVCAM tape – say a 184 minute tape?
  • Mitchji
    July 22, 2005 at 6:00 pm
    [Bob] “Actually, I was looking at it mostly in terms of how to deal with archiving media from the upcoming P2 HD camera from Panny. It records HD onto flash cards, which you offload to HDD. So though the final edit would be laid to some HD tape VTR, what to do with the source selects? Too much for any current DVD (assuming some files might be larger than the media).”
    You could set the maximum file size when importing or exporting from FCP to 4.3 gigs. This will create a semented QT file (one video spread out over multiple physical files). You can then burn these to DVD’s. You could even add a FW DVD-R drive and burn two at a time with multiple copies of Toast.
    This will be a much more convenient workflow when affordable 20 gig Blue Laser discs and drives are available.
    Best Wishes,
    Mitch
  • Bob Woodhead
    July 22, 2005 at 8:12 pm
    Depending on error correction amount used, up to 54GB.
  • Bob Woodhead
    July 22, 2005 at 8:13 pm
    Now there’s a good thought!
  • Bryce Whiteside
    July 22, 2005 at 8:24 pm
    It would seem that the DL DVD+R media at 8.5GB would be perfect to archive P2 8GB media. It do know that media can span 2 P2 PCMCIA flashdrives so I know that would be a concern.
    I know for a fact the latest LaCie DL DVD writers the LaCie d2 have write speeds of DVD-RW: 16x4x12x; DVD+RW: 16x4x12x; DVD+R DL: 4x for $189 list. The LightScribe technology writers are slightly slower at DVD+RW: 16x4x16x ; DVD-RW: 8x4x16x ; DVD+R DL: 2.4x for $199 list.
    The higher capacity P2 media should come out just about the time the higher capacity HD-DVD and BlueLight DVD’s should be coming out.
    Inquiring minds…
    Bryce
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
  • Bryce Whiteside
    July 22, 2005 at 10:00 pm
    The projected P2 capacity increase and storage capacity by time can be found here DVXuser.com ::: Panasonic P2 overview
    Inquiring minds…
    Bryce
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
