Activity Forums Panasonic Cameras Turn Your AF100 into an ENG Camera
  • Rafael Amador
    March 30, 2011 at 9:41 am
    Hi Guy,
    Great tutorial.
    Thanks for bring it here.
    rafael
    PS: You have been nominated my personal AF-100 adviser 🙂
    http://www.nagavideo.com
  • Rafael Amador
    May 4, 2011 at 12:14 pm
    Hi guy,
    I’ve been thinking about this idea.
    Old Betacam lenses are 2/3.
    What about those lenses?
    There are lot of them (Fuji, Canon) and very cheap.
    rafael
  • Guy Mcloughlin
    May 4, 2011 at 5:41 pm
    To use a 2/3″ lens you will need something like the AbelCine HDx2 B4/PL Optical Adapter which doubles the focal-length and enables the lens to fully cover the much bigger m4/3 sensor.
    I expect that this optical adapter is not cheap.
  • Rafael Amador
    May 4, 2011 at 6:44 pm
    [Guy McLoughlin] “To use a 2/3″ lens you will need something like the AbelCine HDx2 B4/PL Optical Adapter which doubles the focal-length and enables the lens to fully cover the much bigger m4/3 sensor.”
    Guy, many of these Betacam lenses have “duplicator”.
    I don’t know much, but a 2/3 lens is a 2/3 lens for HD and for SD. The difference may be that in the SD the lens is framed for 4×3 and in the HD for 16×9.
    The thing is to know if with the same adapter those lenses would work.
    HD lenses are great but too expensive.
    Don’t know if I’m saying a “bêtise”.
  • Guy Mcloughlin
    May 4, 2011 at 8:44 pm
    I think you will have to test, as I can`t imagine that it is this easy, otherwise more people would be using these old lenses, and AbelCine could not charge a lot for their optical duplicator.
