Turn on opacity of a layer using a mark
Hi there. I need a little help on this.
I have two compositions nested. First one (CUBE) has a simple solid and the main one (MASTER) has an adjustment layer with a mark. I need to turn on the opacity of the solid layer with this mark.
In other words, the opacity of the solid will be in 0 and when the indicator pass over the mark named “01” it has to turn on the opacity to 100.Is it possible?. Thank you in advance.
