Activity › Forums › Adobe After Effects Expressions › Turn on/off layer opacity with specific color value
  • Turn on/off layer opacity with specific color value
    Posted by Itay Bartal on January 27, 2021 at 5:16 pm
    The layer opacity is linked to a Color Control.
    I want to turn on to 100 the opacity when I get the color value: [0.973,0.831,0.055,1]
    and if I get other color value I want to turn off the opacity to 0.
    This is what I tried but didn’t work:
    yellow_color = [0.973,0.831,0.055,1];
    if (comp(“_FF_Dark_01”).layer(“CHANGE_COLOR_HERE”).effect(“Color Control”)(“Color”) == yellow_color) {100} else {0}
    THANKS
    Itay Bartal replied 5 years, 7 months ago 3 Members · 3 Replies
  • Kevin Camp
    January 28, 2021 at 6:43 pm
    try just one = (equal sign). I think since it is a numerical value comparison, it should just be one equal.
  • Dan Ebberts
    January 28, 2021 at 8:37 pm
    Colors are arrays, so I think you need to check them element by element. Also, floating point values may not match exactly, so I think I’d include a “close enough” tolerance. Something like this:
    tolerance = .001;
    function compareColors(color1,color2,theTolerance){
    for (i = 0; i < color1.length; i++){
    if (Math.abs(color1[i] - color2[i]) > theTolerance) return false;
    return true;
    color = comp("_FF_Dark_01").layer("CHANGE_COLOR_HERE").effect("Color Control")("Color").value;
    compareColors(yellow_color, color, tolerance) ? 100 : 0
  • Itay Bartal
    January 29, 2021 at 6:47 am
    Like magic!
    THANKS DAN!
