Activity › Forums › Apple OS X › turn off spotlight features by default
  • turn off spotlight features by default
    Posted by Seth Taylor on November 21, 2005 at 8:41 pm
    I really miss the panther way of searching. I don’t need all my files to be searched. Can I turn off the searching of the all the files by default? I want to search by one criteria only, or add criteria from there. Any ideas?
    utah dvd replication – stotion.com
    Jeff Carpenter replied 20 years, 10 months ago 2 Members · 1 Reply
  • Jeff Carpenter
    November 21, 2005 at 9:38 pm
    Once you type a word into Spotlight, hit the Enter key and it will open up a seperate window instead of that pull-down menu it usually uses. You get a lot more control there. There are also ways to use Spotlight technology in the Finder window itself.
    And there are also Smart Folders. There a lot of ways to use Spotlight without actually clicking on that blue icon in the corner.
    Read this:
    https://images.apple.com/macosx/pdf/MacOSX_Spotlight_TB.pdf
