Activity Forums Avid Media Composer Turn off RED LUT in Media Composer ?
  • Turn off RED LUT in Media Composer ?
    Posted by Guy Harding on June 7, 2024 at 1:13 am
    Hey everyone.
    Simple question how do I turn off the LUT I have on some RED footage in the ‘linked Plugin’ window in Media Composer.
    Do I turn the ‘output Gamma’ pulldown to Log ?
    I just simply want to see the RAW LOG media, effectively I just want to remove the linked plugin.
    Thanks.
    Guy
    Guy Harding replied 2 years, 2 months ago 2 Members · 2 Replies
  • Glenn Sakatch
    June 22, 2024 at 2:51 pm
    if you select your clips in the bin, and right click and select source settings, you will find a colour management tab, where you can remove the luts.
    At the bottom of the tab, you will see an “apply to all” button.
    After that, you may need to find the “Update sequence” setting, if you have already cut with the shots with a lut attached, as the sequence will still show the lut, even after you have removed it from the source shots. From memory, i think you right click on the sequence, and you should find an “update sequence” tab. Next to that are options you can update, including Update all, or update colour transforms…or something like that.
  • Guy Harding
    June 23, 2024 at 5:51 am
    Thanks Glen but because its RED there is no LUT in the typical color encoded tab, RED footage’s LUT comes from RMD file and via the ‘Linked-Plugin’ Tab.
    I need to send some clips out to color and I want to send out a Log file.
    Guy
