Activity Forums Adobe After Effects Turn off Opacity expression
  • Turn off Opacity expression
    Posted by Chris Craig on August 18, 2008 at 11:57 pm
    Hi Guys
    Can someone please help me with this simple script. All i want it to do is turn off the opacity of a layer (0%) from 100%, at a specific comp marker (1)
    value[0] – thisComp.marker.key(“1”).time
    Thanks guys
    Chris
    Chris Craig replied 18 years, 1 month ago 2 Members · 2 Replies
  • Peter O’connell
    August 19, 2008 at 3:18 am
    Hi try this expression:
    //start
    var markerTime = marker.key(“yourMarkerComment”).time
    if (time < markerTime) { 0 }else{ 100 } //end Replace yourMarkerComment in the above expression with whatever you type in the comment field of the marker. Hope this works Pete O'Connell roguekeyframe.com
  • Chris Craig
    August 19, 2008 at 3:21 am
    You little beauty!
    Cheers Pete
    I had to manipulate to read the comp marker rather than the layer marker and swapped around the opacity amounts….but it worked beautifully.
    Thank you so much
    Chris
