Activity Forums Adobe After Effects Expressions turn off light layers via scripting?
  • turn off light layers via scripting?
    Posted by Santi Agustí on September 10, 2014 at 1:04 am
    Hi!
    I’d need to turn off all light layers on an entire project (or maybe the option to switch them on/off), and this is not possible via expressions, right? (via expressions using a checkbox would be perfect, but not possible I think)
    Is it possible to be done via scripting?
    Many thanks!!
    Santi Agustí replied 12 years ago 2 Members · 2 Replies
  • Dan Ebberts
    September 10, 2014 at 4:02 am
    You can’t do it with an expression, but you could turn them off with a script like this:
    var myComp;
    for (var i = 1; i <= app.project.numItems; i++){
    if (app.project.item(i) instanceof CompItem){
    myComp = app.project.item(i);
    for (var j = 1; j <= myComp.numLayers; j++){
    if (myComp.layer(j) instanceof LightLayer) myComp.layer(j).enabled = false;
    Dan
  • Santi Agustí
    September 10, 2014 at 5:58 pm
    thanks!!
