Activity › Forums › Apple Final Cut Pro Legacy › Turn mulitview into file
  • Turn mulitview into file
    Posted by Trevor Asquerthian on November 30, 2012 at 4:00 pm
    Multiclip sources (16) are all on the same firewire drive.
    Is there any way of rendering the 16-way multiviewer to a file so that it is playable?
    Any software solutions to create a multiviewer from multiple clips? (without having to manually line them up and apply a transform)
    thanks
    Trevor Asquerthian replied 13 years, 10 months ago 2 Members · 3 Replies
  • Nick Meyers
    November 30, 2012 at 10:07 pm
    no need for motion, you can build the 16 track 4×4 grid in FCP, and export.
    but no you cant export your multiclip view direct from FCP,
    unless you use some sort of screen grab software
    nick
  • Nick Meyers
    December 2, 2012 at 10:37 am
    oh, right,
    i missed where the OP didn’t want to build the 16xSplit in FCP.
    well, they’d all be about the same amount of work, i suspect.
    another way might be to just monitor 9 angles at a time.
    or two multiclips with 8 angles each.
    nick
  • Trevor Asquerthian
    December 2, 2012 at 4:06 pm
    Unfortunately even a 9 way wouldn’t play from a single fw800 drive.
    It wouldn’t be too tricky for them to add the export feature.. Where is the fcp7 feature request list?
