Activity › Forums › Adobe After Effects › Turn a SD video into HD.
Posted by Kate Koyama on September 27, 2011 at 2:59 pmSo I made a video in after effects (640 x 360), but it truns out it needs to be HD (1920 x 1080)
I thought using the camera would help to zoom in, but them everything looks pixelated. Is there anyway to get around it without having to redo everything in a new dimension?
Michael Szalapski replied 14 years, 12 months ago 4 Members · 3 Replies -
Kevin Camp
September 27, 2011 at 3:11 pmyou can try dropping that comp into a 1920×1080 comp and then scale it up to fit (the easy way is to select the nested comp and choose layer>transform>fit to comp). then click the option for continuously rasterize (it’s the layer switch that looks like a little sun icon) and see how that looks.
any vector layer should look perfect, raster layers and effects will look soft, but you’ll have to determine if it’s good enough, or if you’ll need to redo the comp at 1080.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Ben G unguren
September 27, 2011 at 3:13 pmTo go from 640×360 to 1920×1080 is a huge jump in size. If your source files are large enough, you could nest it all in a HD comp, enable the “collapse transformations” switch, and then scale it up 300% and see what happens…. But I’m guessing you’ll have to redo it at the larger size.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Michael Szalapski
September 27, 2011 at 4:38 pmTry the resize comp script that comes with AE. But first, save a copy of the original project just in case.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
