Activity Forums Apple Final Cut Pro Legacy Turn a SD video into HD
  • Turn a SD video into HD
    Posted by Jay Fishback on December 7, 2011 at 3:31 pm
    So i know you cannot turn SD footage into HD footage automagically as Dr. Tuneup (Biz Markie) would put it, but the footage was originally recorded on a 5D and coded through compressor into DV NTSC. I know I should have initially coded it into ProRes, but at the time I couldnt afford the extra space on my harddrive. So I know pretty basic things about final cut (a photographer in a moving world) but is there a way to time stamp the clips so all I would need to do is code the correct footage into ProRes and then walla its there. I have FCP 7.
    Here is a link in case you are interested.
    https://vimeo.com/22419848
    Jay Fishback replied 14 years, 9 months ago 2 Members · 2 Replies
  • Mark Suszko
    December 7, 2011 at 3:40 pm
    You use Media Manager to re-import the high rez footage matching what you’ve edited, and if everything works as it si supposed to, you should end up with the same edit in HD.
  • Jay Fishback
    December 7, 2011 at 3:45 pm
    Thanks Mark. I will do that.
