Activity Forums Adobe After Effects Expressions Turbulence in 3d space
  • Turbulence in 3d space
    Posted by Mikael Holmström on May 9, 2021 at 7:06 am
    I would like the position of layers (in 3d space) to be affected by a “turbulence field”, much like the one affecting particles in, for instance, Trapcode Particular. I’m looking for some kind of randomness added as an expression to the position property of each layer, but a randomness that is driven by its position rather than – like in the wiggle expression – time.
    To make this work I also would need to be able to tweak the scale, the amplitude and (if possible) the evolution over time for the turbulence randomness.
    Is this possible?
    /Mikael
    Mikael Holmström replied 5 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 9, 2021 at 1:51 pm
    You should take a look at the noise() function. It gives you a Perlin noise field and will accept a 3-value array as its input parameter, so you could navigate the field using scaled x,y, and z position values and might also be able to incorporate time in some clever way.
  • Mikael Holmström
    May 9, 2021 at 6:50 pm
    Thanks, Dan, this really got me going in the right direction! I’m about to build myself the slowest particle generator of all times (but with the powerful benefit of having full control over each particle) 🙂
