Activity › Forums › Maxon Cinema 4D › Turbulence FD don’t want to render with my GPU
  • Turbulence FD don’t want to render with my GPU
    Posted by Maxim Fischer on July 16, 2017 at 8:23 pm
    Hello.
    So I’m trying to do a simulation with the Turbulence FD plugin. The default render hardware is my cpu and it takes so much time to render a frame.
    When I choose my gpu instead of my cpu it switches back to my cpu. I don’t get it. I can select my gpu while rendering and shows the vram from the gpu, but after few seconds its switching again to my cpu. I updated my drivers to the latest and the internet isn’t helpful. Maybe some of you guys have a solution.
    My gpu: GTX 1060 6GB Gainward Phoenix
    CPU: i5-4690k 4,4GHz
    Natalie Ivanova replied 5 years, 12 months ago 4 Members · 7 Replies
  • 7 Replies
  • Jim Scott
    July 16, 2017 at 9:12 pm
    Hi Maxim,
    I know that Turbulence FD will switch back to the CPU when it runs out of GPU memory, but I wouldn’t think that would happen after only a few seconds unless you are trying to run a massive simulation.
    If you want to post your project file I’ll try running it on my GTX 980 Ti 6GB and see what happens.
  • Maxim Fischer
    July 16, 2017 at 9:31 pm
    Hello Jim,
    thanks for your fast response. Here is the file:
    https://f1.creativecow.net/11524/smoke-simulation?uploaded=file
    Good luck ????
  • Jim Scott
    July 16, 2017 at 10:10 pm
    When you say “render” I’m assuming you were referring to running the cached simulation. When I ran it, it took about 3 min. 30 seconds for the full 300 frames. As far as I could tell it was running on the GPU the whole time, indicating that it was using around 1.7GB of the available 6GB. If I run it with CPU selected it estimates over 20 minutes.
    What do you see when it switches back to the CPU? Does the selection window switch to that, or what?
    I am leaving to go to my granddaughter’s 1st birthday party, so I will check back later.
  • Adam Trachtenberg
    July 17, 2017 at 3:53 pm
    Do you have the most recent nVidia drivers installed? If not that could be the problem.
  • Maxim Fischer
    July 17, 2017 at 5:08 pm
    Okay now I get an error message.
  • Maxim Fischer
    July 17, 2017 at 5:09 pm
    Yes I have :/
  • Natalie Ivanova
    October 6, 2020 at 2:44 pm
    Hey, Max, I’m having the same issue 🙁 Did you find out how to fix it?
