Activity › Forums › Maxon Cinema 4D › Turbulence FD + Arnold visibility problem [C4D]
  • Turbulence FD + Arnold visibility problem [C4D]
    Posted by Christian Balistrari on October 1, 2019 at 3:17 pm
    Hi everyone, hope you can help, tested TFD with standard and physical renderer in C4D and renders fine however unable to get things working in the IPR/final render when using with Arnold..
    My Arnold workflow:
    – Setup simulation exactly the same
    – Add Arnold parameter tag to the TFD Container
    – Add Arnold standard volume after the parameter tag
    – Same simulation and viewport settings on the TFD container
    I can see the cached simulation in the viewport absolutely fine, when I head into the IPR window I get the full scene rendered but without any of the TFD simulation.
    Any thoughts on a solution would be fantastic as not sure what to try next.
    Thanks.
    Sam Treadway replied 6 years, 11 months ago 2 Members · 3 Replies
  • Sam Treadway
    October 2, 2019 at 11:16 am
    Try following these instructions from the Arnold docs:
    https://docs.arnoldrenderer.com/display/A5AFCUG/Turbulence+FD
  • Christian Balistrari
    October 4, 2019 at 10:22 pm
    Hey mate, thanks for the reply, I’ve followed those docs and a few tutorials but to no success, makes me think there’s and incompatibility somewhere, unless I’m missing something obvious.
    Thanks again.
    arthrmusic.com
    Music | Animation | Live
  • Sam Treadway
    October 4, 2019 at 11:00 pm
    I don’t know then. As an alternative you could try exporting the cache as openVDB and then create an Arnold volume and link to that VDB.
