Activity › Forums › Maxon Cinema 4D › Tunnel Loop in c4d
  • Tunnel Loop in c4d
    Posted by Pat Mat on June 21, 2016 at 11:22 pm
    Im looking to do a camera travelling inside a tunnel inside a cylinder, while thecamera follows a spline.
    Any recommendation do do that, to create a seemless loop?
    Thanks.
    Patrice
    Adam Trachtenberg replied 10 years, 3 months ago 3 Members · 3 Replies
  • Brian Jones
    June 22, 2016 at 2:36 am
    lots of advice out there, do a search here for ‘wormhole’. If that’s not the sort of thing you’re after more details would be necessary (for me anyway)
  • Pat Mat
    June 22, 2016 at 1:23 pm
    Yes got a way to do it, thanks!
    One more question.. I want to get a scale effect, like scale from 100 to 50 to 100, on a cloner with a form. What would you suggest?
    Lets say i have an object inside a cloner and i want it to get affected so it scales from when passing on. I know there is a way to do it.
    Thank you!
  • Adam Trachtenberg
    June 22, 2016 at 9:41 pm
    Sounds like you’d want to use a Plain Effector with falloff. Turn on the Scale parameter, check the Uniform scale box, and set the value to 0.5.
