Activity › Forums › Maxon Cinema 4D › Tumble Weed
  • Tumble Weed
    Posted by Miamo Kotallebi on June 12, 2016 at 2:03 pm
    Hi I’m trying to get a tumble weed to ‘tumble’ in the wind. Problem is I can’t get it to roll naturally. How does one go about rolling an irregular shaped object to roll on a service. Roll-it plugin does not work with R11-14 . I can only get a particle emitter to blow the weed across the floor plane, no rolling. Ideas?
    Miamo Kotallebi replied 10 years, 3 months ago 2 Members · 4 Replies
  • Brian Jones
    June 12, 2016 at 4:49 pm
    what version of C4D do you have (and what package)? It’s very possible with Dynamics but it’s also possible with xpresso
  • Miamo Kotallebi
    June 12, 2016 at 5:23 pm
    Hi, I’m running R14 Studio
  • Brian Jones
    June 12, 2016 at 7:29 pm
    depending on how detailed your tumbleweed is (geometry or texture based) you might want to use a simple thing like in the example file (but fitted to your tumbleweed) as a proxy for quicker calculation. Here is a simple test with a Wind object pushing a “tumbleweed” with enough friction in the ground and tumbler to make it roll instead of slide and with Rotational Mass set low enough it can do that easily.
    10187_tumbleweedtrial.c4d.zip
    this is what I mean by proxy
    10188_tumbleweedtrial2.c4d.zip
  • Miamo Kotallebi
    June 12, 2016 at 7:39 pm
    Thank you soo much! I’ll have a go at it. I think it’s exactly what I needed. So kind of you to do this.
