Activity Forums Apple Final Cut Pro Trying to use “sync clips” with clips from different events
  • Trying to use “sync clips” with clips from different events
    Posted by Michael Williams on August 22, 2014 at 3:14 am
    Hi All,
    The new project has 7 different types of cameras, with several cameras in each type. Clips were imported into events according to camera type.
    Is it possible to use keywords or some other technique to choose overlapping clips from each event, then call the Synchronize Clips on them, so they will line up according to the audio? It appears the start times of the cameras / clips were not exactly in sync to begin with.
    FCPX, MacPro, Mavericks
    Ron Priest replied 12 years ago 2 Members · 3 Replies
  • Ron Priest
    August 22, 2014 at 3:39 am
    No, you can’t sync clips from multiple events, they must be in the same event. You can copy the clips from one event to another, but you should have imported all of the clips into the same event in the first place. I would have assigned camera names and angles to the clips as I imported them from each camera, then you could select all of the clips and synchronize them.
    Ron Priest
    Videographer
    Louisville, KY
  • Michael Williams
    August 26, 2014 at 7:22 am
    Hi Ron,
    update.. selecting clips from different events and syncing them can be done! The trick is using the Filter function in combination with keywords applied to clips across all events.
    Also, there is a sort by function on the Libraries List under the gear pull down, to sort by date, which will group clips created at the same time together for synching.
    Michael
  • Ron Priest
    August 26, 2014 at 1:14 pm
    Okay, I stand corrected then. Im glad you were able to figure that out! I’ll have to try that.
    Ron Priest
    Videographer
    Louisville, KY
