Activity › Forums › Avid Media Composer › Trying to use 720/24P in Avid Media Composer 5.52
  • Trying to use 720/24P in Avid Media Composer 5.52
    Posted by Jeremy Hansen on July 21, 2011 at 10:56 pm
    Hello everyone,
    I shot some footage on my HVX200 in 720/24P instead of 720/24PN and am having weird issues when trying to use it in Avid Media Composer 5.52.
    I downloaded the P2 cards onto a drive and am using the Link to AMA files to get them into a bin.
    The project that I made is 720/23.976. When I play the material, the frame rate is obviously off as the image is slow and jittery. I experimented with various projects/frame rates and haven’t had any luck.
    The second issue is that the audio doesn’t show up unless I manually go into the Audio folder and link to those AMA files as well. Is that normal?
    Thanks everyone for your time.
    – Jeremy
    Jeremy Hansen replied 15 years, 2 months ago 3 Members · 4 Replies
  • Shane Ross
    July 22, 2011 at 12:23 am
    Make a 720p 59.94 project. 24p (non-PN) runs at 59.94…it just has the 24p “look.” Try that and see what happens.
    Shane
  • Jeremy Hansen
    July 22, 2011 at 1:47 am
    Hi Shane,
    Thank you for your response. I had found out about the 59.94 through my research and showed no change.
    Strange thing though, now I’m seeing that if I play the footage directly from the P2 cards in the camera, the footage is fine. Whilst when I play AMA footage that I transferred to my hard drive, I am having problems with slowed down image and jitters. Perhaps copying straight from the P2 cards to the hard drive is not the best way to transfer the footage…?
  • Ricky Barrow
    July 22, 2011 at 12:43 pm
    We shoot P2 and found that 720/30p is actually shooting 60 with a flag to playback 30 – Avid doesn’t seem to recognize this and gives me the green dot in the timeline of a 720p/29.97 project when linking AMA. When we shoot 720p/30PN – we get 30 frames and Avid is happy. Copying P2 drives has not affected us and shouldn’t affect you as long as you keep the P2 structure in place – the computer doesn’t care. We found AMA linking to volume brings the media back without going through relinking when changing from one Avid room to another.
    Ricky
  • Jeremy Hansen
    July 22, 2011 at 7:47 pm
    Thank you for your responses.
    The problem appeared to stem from the hard drive transfer. I used the consolidation tool in the clip menu instead to move the clips from the P2 cards to my hard drives and now they are running smoothly. A strange issue, but at least it’s resolved.
    – Jeremy
