Activity › Forums › Apple Final Cut Pro Legacy › Trying to understand settings and find media please help
  • Shane Ross
    January 27, 2010 at 5:29 am
    OK…
    The location that you set as the Capture Scratch…in that location, do you see a CAPTURE SCRATCH, RENDER, AUDIO RENDER as well as a FINAL CUT PRO DOCUMENTS? Because when I set my capture scratch to a hard drive or folder, those are the files that show up. I don’t get a FINAL CUT PRO DOCUMENTS folder, then the list of subfolders. Only if I choose my DOCUMENTS folder as the location.
    [Roli Rivelino] “Project B has the original ingested media in my import folder and the FCP media is in the Project B folder in my capture scratch”
    Gotcha…
    [Roli Rivelino] “the new Project A the original ingested media is in my import folder”
    Where is this IMPORT folder? In FCP in the Browser?
    [Roli Rivelino] “BUT the FCP media is not in a Project A folder in the capture scratch. “
    Where is it? When you REVEAL IN FINDER, where does it show the media as being located? What is the file path?
    Shane
  • Roli Rivelino
    January 27, 2010 at 9:29 am
    Cool, we’re getting there now :-).
    Shane: The location that you set as the Capture Scratch…in that location, do you see a CAPTURE SCRATCH, RENDER, AUDIO RENDER as well as a FINAL CUT PRO DOCUMENTS?
    Yes I do
    Shane: I don’t get a FINAL CUT PRO DOCUMENTS folder, then the list of subfolders. Only if I choose my DOCUMENTS folder as the location.
    I do see them like this, I think originally I made the FCP Documents folder myself or as you suggested used my Documents folder as the location.
    Shane: Where is this IMPORT folder? In FCP in the Browser?
    The folder is on my 2nd drive; which incidentally I’ve named FCP scratch, but let’s keep calling it 2nd drive to avoid confusion! (could that naming be confusing Final Cut?)
    Shane: Where is it? (Project A) When you REVEAL IN FINDER, where does it show the media as being located? What is the file path?
    The file path is 2nd drive > Import folder > Project A folder > Clip 1A
    and even if I make a subclip of Clip 1A then the file path is still the same.
    If I do a reveal for Project B it shows a file path that makes sense
    2nd drive > Final Cut Documents > Capture Scratch > Project B Folder > Clip 1B
    Weird huh? And to make things even weirder (to me anyway) there IS a Project A folder (along with Project B and all my other projects) in the Render Files folder and the Autosave Vault and Audio Render Files.
    Thanks for your patience and time with this.
    aka Newbie Wan Kenewbie. “The young Newbie, is now a Padawon.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
Page 2 of 2
