Trying to tally keyframe values
I’ve been struggling to make this work. Maybe someone here has an idea.
I have two sliders. Slider A and Slider B.
Slider A has several keyframes of various values.
Every time it has a value of 5 I want to add 1 to the value of Slider B, but all I can seem to do is get it to “change” its value, not add to it. Once Slider A’s value changes, Slider B goes back to normal.
As you can see what I’m trying to do is tally the number of times a specific value is represented. I intend to do this for several other values too, but for the sake of this example, this is enough.The closest thing I’ve found to this is a counter that counts the number of times a ball is in a certain part of the screen. It’s not quite the same, but the concept is pretty similar.
https://creativecow.net/forums/thread/position-increment/I’m not much of a scripter, I just know enough to repurpose scripts and do a few simple things, so if anyone thinks they know how this can be done, have at it. 🙂
