Activity › Forums › Apple Motion › trying to stabilize footage
  • trying to stabilize footage
    Posted by Nick Meyers on July 9, 2009 at 6:32 pm
    hi there.
    i’ve been using FCP for 9 years, but am a novice when it comes to motion.
    i’ve recently had some old super-8 footage telecined.
    there’s a fair bit of weave, and the frames ride up when a splice goes through.
    we telecine with a bit of overscan, and the sprockets are visible in the left hand side of the frame,
    so i figure i should be able to “pin” those sprockets somehow, and override the gate drift.
    (the footage in the shots is hand-held, which is fine by me. i don’t want to smooth that out, just get rid of the gate drift)
    i’ve been trying to find how to do this in the manual, but am feeling a bit bamboozled.
    (it says you can do this, but i can find where it outlines a process)
    if its not to hard could someone outline the process (so an idiot can understand it!)
    alternatively, if you can point me to some on-line tutes, that’d be great.
    (I had a look for some, but most “stabilize ” tutes deal with simply smoothing out a hand-held shot, or similar)
    thanks,
    nick
    Nick Meyers replied 17 years, 2 months ago 2 Members · 2 Replies
  • Ariane Fisher
    July 10, 2009 at 4:31 pm
    What kind of system are you using? Using motion for stabilization does work quite well, but is extremely processor and time consuming, even on a 2 second clip.
  • Nick Meyers
    July 10, 2009 at 11:07 pm
    thanks for responding.
    i’m on an 3GHz Octocore with 4G of ram.
    since i haven’t been able to figure out how to do what i want,
    speed isn’t my problem… yet!
    would you have any tips on stabilizing shots by “pinning” certain points?
    thanks,
    nick
