Activity Forums Apple Final Cut Pro Legacy Trying to split Audio to R & L Still not getting it.
  • Trying to split Audio to R & L Still not getting it.
    Posted by Ed Stevens on December 13, 2005 at 3:51 pm
    My SYSTEM
    MAC dual G5 2.5 gig. 4.5 gb RAM. OS 10.3.8
    Blackmagic Decklink Extreme card v4.8b
    FCP 4.5 production Suite
    1 300gig scratch disc
    500GB G-Raid Firewire800
    Decks = Beta-SP, DVCpro, DigiBeta.
    Audio Mix = Mackie 1604 VLZpro
    I believe I have the stock display card
    Panasonic AJD-230H DVCpro deck
    I need step by step help. Looked all through the manuals.
    It was told to me once that if you highlight all the audio tracks in ht etimeline that you wantto separate, then hit OPTION, ti will go to one channel and OPTION/ willtake it to the opposite channel. This works but it only does it to the first clip in the timeline. It does not do it to the rest that have been hi-lighted. I have VO stereo pair on Trks A1a and A1b. I want these on 1 channel. I have music on Trks A2a, A2b, A3a, A3b. I want these on the other channel. Just can’t get this to work. I’m not a wiz at FCP yet so I need step by step.
    Thanks in advance.
    ED
    Mark Gringo replied 20 years, 9 months ago 4 Members · 6 Replies
  • Andy Mees
    December 13, 2005 at 4:11 pm
    you might save yourself some trouble by getting rid of the whole stereo pair thing, and going to dual mono instead
    if you go to your sequence settings, audio outputs tab you will notice a setting called “Grouping” for each audio pair, which can be set as stereo or dual mono
    if you change your outputs to dual mono then you will be able assign your tracks to the individual outputs eg “A1” or “A2” instead of “1 & 2”
  • Ed Stevens
    December 13, 2005 at 5:43 pm
    I thank you for your response but no dice. I have made the tracks dual mono. I right clicked at the auto preset and made the VO track1. I then made the music Track 2. They still are not split.
    ED
  • Mark Gringo
    December 13, 2005 at 6:41 pm
    if there is a way to do this, i’d love to know about it. i just finished doing an hour by hand in the audio mixer window… paning each audio clip L or R. not alot of fun.
  • Jeremy Garchow
    December 13, 2005 at 8:45 pm
    Okay all, here’s the step by step.
    Make sure the current timeline you want is open and active. Hit Apple-0. Select 2 channel output and then select dual mono (as opposed to stereo). Now, control click the track right by the autoselect button and select which output you want. In your case, Ed, you want a1&a2 to be set to 1, and a3-a6 to be set to 2. This will send channels a1 & a2 out to channel 1 of your deck or mixer, and the rest of the channels out to channel 2. Open the mixer in FCP (option-6) and toggle the button just above the master output, it looks like two speakers butting heads, or kissing, or whatever. That determines if FCP downmixes everything to stereo, or if it splits it to the assigned tracks. This downmix button will apply to monitoring AND to laying off to tape. If you want split tracks, you need to click this downmix button to hear and layoff correctly. This procedure also applies to 4 or more tracks of output.
    Good luck and hope this helps.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
  • Ed Stevens
    December 13, 2005 at 9:04 pm
    You get the prize. Thanks so much. It works. The key here was clicking the twin speakers above the master control. Thanks again. This is what makes this site so great. Full of great people.
    ED
  • Mark Gringo
    December 14, 2005 at 4:29 pm
    this is great to know! mucho thanks!!
