Activity › Forums › Apple Final Cut Pro Legacy › Trying to speed up HDV PAL b-roll to 30FPS
  • Trying to speed up HDV PAL b-roll to 30FPS
    Posted by Ted Sikora on August 19, 2008 at 1:43 pm
    I’ve looked high and low on this, with no luck.
    I’ve got an HDV editing job that was mostly shot at 29.97FPS, but two tapes are from a camera that was shooting at HDV PAL 25FPS. It’s B-Roll of a ship, so speeding it up would be ideal.
    I don’t want to do anything that mucks with the fields. I just want to speed up the PAL so I’m getting about an extra 5 frames a second. Speeding it up to 119.88% did not do it – it created new frames, fields, and interpolations.
    Any thoughts or ideas would be greatly appreciated.
    Ted Sikora
    Sean Oneil replied 18 years, 1 month ago 4 Members · 3 Replies
  • Ed Dooley
    August 19, 2008 at 4:29 pm
    Have you looked into Compressor or Nattress filters?
    https://www.nattress.com/Products/standardsconversion/standardsconversion.htm
    Ed
  • Bob Flood
    August 19, 2008 at 8:19 pm
    Hi
    I had to do the same standard convert, just different formats
    ie i had a 29.97 dv50 show and had to integrate 25 DV.
    I think i just batch conformed everything from 25 to 29.97 in cinema tools, then slowed the stuff down where i needed it, which was only a few places, as the subject matter got better when sped up!
    hope this helps
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Sean Oneil
    August 19, 2008 at 8:55 pm
    Conform in Cinema Tools, like what Bob said. That’s the way to do it.
    Sean
