Trying to set up FCP 7 editing from Seagate Central Ethernet drive and back up on Backup Plus local drive
I’m frustrated. I just purchased a 4TB Seagate Central Drive (cat 6 cord from gigabit router to drive, then cat6 cord to Mac Pro). I also purchased a 4TB Seagate Backup Plus drive that is connected via USB 3 directly to Mac Pro.
All I want to do is store ALL of my video folders on the Central drive, be able to edit from them, then run backups of the contents of the Central drive to the Backup Plus. Sounds simple, but it’s not.
If I add clips to the Central and try to edit, I get General Errors and other errors. It doesn’t work. I read I have to create disk images in Disk Utility locally, then drag to Central drive. But that seems like a workaround and not a solid solution.
How do I simply add all projects to a Ethernet drive, edit from them and have the contents back up to my local Backup Plus Drive? I’m pulling my hair out and need to get editing.
I’m ready to just dump all video to the backup drive and start working, and figure out a way to backup everything to the Central drive. (which seems backwards, but I have no other ideas).
Thanks for your help!
Josh
