Activity › Forums › Apple Final Cut Pro Legacy › Trying to remove colored flicker from LED lights on live shoot footage from DVX
  • Trying to remove colored flicker from LED lights on live shoot footage from DVX
    Posted by Nharley on February 21, 2007 at 5:40 pm
    I figured out that I was supposed to set the synchro scan rate to match the lights after the fact I realized that emitted light like a computer monitor. But now my footage has this horrible annoying colored flickered strobe effect to it due to the lights not being synched to the cams. How would I alter this in post in FCP? I know I can do it next time at this venue with some setup, but after the fact…I have no idea. PLEASE HELP…its for a burlesque troop
    THANKS!
    Nick
    David Bogie replied 19 years, 7 months ago 3 Members · 2 Replies
  • Tom Meegan
    February 22, 2007 at 10:47 am
    I remember a thread on this problem in the Apple Discussions from a while ago. I just searched over there, but did not find it. I’ll try to summarize what I remember.
    First the painstaking, awful way.
    Step through your footage frame by frame, and see if you can identify the pattern. How many times does the footage change before the cycle starts again?
    Choose a reference frame
  • David Bogie
    February 22, 2007 at 5:11 pm
    It can be done. You have two choices:
    1. Slog through it, frame by frame, as Tom has described. (There are many ways of approaching this in AE; they all bite.)
    2. Hire someone to do it for you. (You will only resent the tedium.)
    Okay, three choices:
    3. Reshoot. (Probably easier and cheaper.)
    Wait, four. You have a fourth choice:
    4. Live with it. Call it a deliberately planned stylistic approach instead of a flaw.
    bogiesan
