Activity Forums VEGAS Pro Trying to reduce file size on DVD project
  • Trying to reduce file size on DVD project
    Posted by Rick Rintala on December 18, 2007 at 1:40 am
    I have a wedding that I am preparing a DVD for. I have about 88 minutes of video in the project. When I try to prepare/render/burn the project it tells me the project size is to big for the media. I show 5.1 GB in the bottom right of the work space. I am rendering as MPEG2 – DVD NTSC – Video render quality is Best. I jumped from Vegas 4 to Vegas 7. I used to be able to get 2 hours on a DVD no problem. Is there something in the render settings that would help the file sizes and not reduce the quality too much?
    Mike Kujbida replied 18 years, 9 months ago 2 Members · 1 Reply
  • Mike Kujbida
    December 18, 2007 at 2:13 am
    DVD Architect is famous (or is that infamous??) for incorrectly reporting file sizes.
    Check the actual file sizes of the MPEG-2 & AC-3 streams that you rendered and, if they’re under the 4.3 GB limit, ignore the warning and render.
    BTW, my bitrate calculator gives a CBR of 6300 or a VBR of 7800/6300/3700.
    If your numbers are close to that, once again, ignore the warning.
