Activity Forums Audio Trying to reduce feedback with wireless mics for a board meeting
  • Trying to reduce feedback with wireless mics for a board meeting
    Posted by Dan Shaw on February 20, 2015 at 10:52 pm
    I am hoping to get some ideas on how to best prevent feedback given my situation when working the audio board for a school district board meeting. Unfortunately, I can’t rearrange things. So I can’t re-position the output speakers or the individuals who have the microphones. The location also does not help as it is in a large room that has some echo.
    What I am finding is that if the audio levels are too high, I get feedback. But if I lower them down to prevent that feedback, it gets too quiet. So the last couple of meetings I have been working my butt off to turn off all the mics except for the person speaking. This has helped a lot, but they talk sometimes so fast that I can’t keep up. It would be great to try to keep all of the microphones on so that I don’t have to babysit as much.
    Other difficulties:
    – Wireless mics are on small stands that sit in front of the board members.
    – Members have bad mic techniques. Some are really close and others are farther away. So I have had to turn up the soft talkers and lower the loud talkers.
    – Members are sitting next to each other in a horse shoe like pattern.
    – Two large speakers are above the board members (mounted to the wall)
    After researching, things others have suggested:
    – Find the frequency that the feedback is coming in on and reduce it with EQ. Best option? I don’t have a graphical EQ board. Just a mixer with EQ knobs.
    – Look into a limiter/gate to block out the reverb. (I shy away from this as it costs $$$)
    – Continue to ride the mixer and turn off mics that are not being used.
    Ultimately I’d love to not have to spend money. In fact, I don’t think I can spend any money right now. Gotta love public education. So I would love some ideas on what I can do as an amateur audio engineer. 🙂
    Thanks guys! And let me know if I didn’t give enough details. I’m new to this.
    Peter Groom replied 11 years, 2 months ago 6 Members · 17 Replies
  • 17 Replies
  • Brian Reynolds
    February 21, 2015 at 12:19 am
    I have used these and had good results….
    https://www.behringer.com/EN/Products/FBQ100.aspx
    Not going to totally fix the problems you have unless you do a complete rejig….
    A trick I have often used is to actually turn the level down on people with bad mic technique and tell them how much better good technique sounds as seen on other people….. Guess what they learn fast 😉
  • Ty Ford
    February 21, 2015 at 12:25 am
    Hello Dan and welcome to the Cow Audio Forum.
    How many mics are you running?
    How many people are talking into them?
    Can you please post a picture of the setup?
    Regards,
    Ty Ford
    Cow Audio Forum leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Ryan Miraglia
    February 21, 2015 at 9:51 pm
    If you have the option, for low talkers turn gain up on the handheld unit itself, and down for louder folks. Tell speakers to speak INTO the mic.
  • Brian Reynolds
    February 21, 2015 at 11:07 pm
    While ‘chasing levels’ for low speaking persons actually creates problems for ‘YOU’.
    I do some annual AGM type meetings and was faced with similar problems and then changed the tack to lowering (slightly) the level on people that aren’t prepared to use a mic properly….. They are then ‘forced’ to raise the mic to their mouth and then i will then raise the level to get good results.
    Also by people seeing that poor mic technique gives poor / almost acceptable results they will continue to do it, perpetuating the problem for future generations of ‘sound mixing people’
    If anything is said by the organisers just say ‘I was doing my best but when people refuse to use a mic correctly there is not much I can do’
  • Ty Ford
    February 22, 2015 at 12:17 am
    Or, toss out the table mics and rig them all with Headworn mics like the countryman B6. They can’t get away from them and they are very lightweight.
    Regards.
    Ty Ford
    Cow Audio Forum Leader
  • Dan Shaw
    February 24, 2015 at 9:08 pm
    Thanks everyone for your suggestions. I do agree that having bad mic technique is most likely the biggest issue that I have. I have the board meeting tonight so I am going to talk with the board and remind them on how best to talk into the mic. It would be nice to just attach the mic’s onto their bodies so that they don’t have to talk into the mic on the table, so I might bring that up and give it a try.
    Ty – To answer your questions, I have 1 wired mic for any community member to talk into, and 8 wireless mics for the board members. These wireless mics are plugged into small table mics that stand in front of each board member. The board is constantly talking throughout the night.
    I am including a photo of the room, but the layout of the tables is not correct on this photo. The woman who you see there is facing the direction of how the board would be facing. You can also see one of the large speakers on the wall. Once the tables are set up it resembles a horse-shoe pattern.
  • Ty Ford
    February 24, 2015 at 9:23 pm
    Hmm, can’t tell exactly, but angling the speakers towards the right in the room and away from the mics might help some.
    Basically, it’s a rock and a hard place situation. If people don’t get up on the mic, there’s not a lot you can do.
    Are the mics only for PA? If they are there to record what’s said, then if you have a gain control after the recorder for the PA, then you can get good record levels and adjust the amount that goes to thew PA system. That’ll allow you to stay further away from feedback.
    Regards,
    Ty Ford
  • Jo Llereza
    June 27, 2015 at 2:11 am
    Hi Dan,
    I was wondering if you found the solution to your feedback and mic level issues for the board meetings.
  • Dan Shaw
    June 29, 2015 at 4:41 pm
    Jo – At first I pushed the board members to practice good mic technique. That lasted for about an hour and then they went back to their old habits. It’s a ton more work, but what I have ended up doing is turning half of the mics off for the few board members that seem to not talk as much. This allows me to increase the volume without any feedback. I then have to stay alert and enable their mics when they do talk. As long as I don’t have all of the mics on at the same time it sounds fine. And while it takes more effort on my part, they do appreciate it. This meeting is only once per month. If it were a daily event I would look more into how I could reduce this feedback.
    -Dan
  • Ty Ford
    June 29, 2015 at 5:44 pm
    Hey Dan,
    A couple of automixers (shure and Audio-technica sell them) will also work in your situation.
    Regards,
    Ty Ford
