Activity › Forums › Adobe After Effects › Trying to recreate an effect (Something similar to smoke text)
  • Trying to recreate an effect (Something similar to smoke text)
    Posted by Cypert Costa on April 8, 2018 at 12:39 pm
    Hello, I’m trying to recreate this effect https://youtu.be/u81WzbhqdaU
    To do that I’ve tried converting a rectangular shape layer to an adjustement layer, applying here the effects “Turbulent Displace”, “Fast Blur” and “Wave Warp”, and moving this layer to make it them stop effecting the text below, but I’ve 2 problems, the effects it’s not the same, it’s kind of similar but not close enough and I the second one is that I don’t know how to make the transition between the part with the effect and the one without seamless (Sorry for my english, I’ve attached an image to try to explain what I mean)
    Cypert Costa replied 8 years, 5 months ago 3 Members · 4 Replies
  • Kalleheikki Kannisto
    April 8, 2018 at 4:42 pm
    What I suspect they have done is use an animated soft fractal noise and used that noise to drive both displacement and lens blur effects. Then applied a levels adjustment on the fractal noise to bring it from full white to full black (with the fractal in shades of gray in between those extremes).
    Senior Graphic Designer
  • Cypert Costa
    April 8, 2018 at 5:55 pm
    Thank you for your answer, I’ll try it
  • John Cuevas
    April 9, 2018 at 3:20 pm
    Looks very much like this old technique:
    Flowing Title Effects
    Project files are way out of date, but if you follow the steps you will get basically the result you are looking for.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Cypert Costa
    April 13, 2018 at 9:37 pm
    Thank you, I’ll try it this weekend
