Activity Forums DaVinci Resolve Trying to output HD to EIZO CG241W trough HDLink PRO with no success
  • Trying to output HD to EIZO CG241W trough HDLink PRO with no success
    Posted by Mikhail Puzyrev on February 17, 2011 at 7:58 pm
    Hello everybody. Tried to monitor 1080 p, psf, i 50 through HDLinkPRO to EIZO CG241W but didn’t work. PAL SD is ok. Output processing on Extreme 3D is switched off. When switch Resolve monitoring to any HD format – monitor goes black and eizo power light goes yellow from blue.
    Mikhail Puzyrev replied 15 years, 6 months ago 3 Members · 4 Replies
  • Josh Petok
    February 18, 2011 at 5:02 pm
    I had a similar problem. I loaded up a new version of the firmware and all was well. After the firmware is updated, be sure to fully power down everything and bring it all back up again.
    Josh Petok
    JoshPetok.com
  • Mikhail Puzyrev
    February 19, 2011 at 9:19 am
    Thanks! Actually new firmware was loaded long ago. The only one thing needed was opening HDlink utility Preferences and checking on “Override monitor’s preferred EDID settings” radio button on!
  • Fred Ricci
    February 22, 2011 at 9:38 am
    Hi Mikhail, how did you calibrate the Eizo?
    NEHALEM OCTO 2,26
    GT 120
    GTX 285
    8 Giga RAM
    SOFT RAID 8 Tera
    Wave
    Eizo 243 + Hdlink displayport
    DAV, COLOR, FINAL CUT AND MEDIA COMP
  • Mikhail Puzyrev
    February 22, 2011 at 8:32 pm
    Still in process. Results are frustrating )))
