Activity Forums Adobe After Effects Trying to make one shape rotate with a 5 seconds delay behind another shape
  • Trying to make one shape rotate with a 5 seconds delay behind another shape
    Posted by jess Mah on January 31, 2025 at 9:35 pm
    Hey all, I am new to ae expressions and by no mean a math genius. I thought this expression will drive the lower layer to rotate 5 seconds behind the top layer but they are rotating in sync. the expression seems valid with no error. What did I miss here?
    Top layer (index 2):
    var initialRotation = 0;
    var rotationIncrement = 10;
    var currentRotation = initialRotation + rotationIncrement + Math.floor(time);
    [currentRotation]
    Bottom layer (index 3) :
    var R = thisComp.layer(index-1).transform.rotation;
    var P = R.valueAtTime(time-5);
    [P]
    https://youtu.be/3EoU6TzPLM0
    Brie Clayton replied 1 year, 6 months ago 3 Members · 3 Replies
  • Dan Ebberts
    February 2, 2025 at 7:39 am
    If you look at the rotation values in the graph editor, you’ll see that the lower layer is actually 5 seconds behind the upper layer.
    Just a couple of notes on your expressions. You don’t need the final variable, and you don’t need to put the result in brackets (because rotation is a one-dimensional property), so this would do for the top expression:
    and this for lower one:
    Also, I’m wondering if the upper rotation is actually what you meant to do or whether you needed a multiplication, like this:
    initialRotation + rotationIncrement * Math.floor(time)
  • jess Mah
    February 21, 2025 at 5:00 pm
    Thank you !!! The top one works like I intended – its a very elegant solution! 😀
  • Brie Clayton
    February 22, 2025 at 3:13 pm
    Thank you for this solve, Dan!
