Activity › Forums › Adobe Premiere Pro › trying to make my 30fps footage look like “hyperlapse” footage
  • trying to make my 30fps footage look like “hyperlapse” footage
    Posted by Jon Melot on March 20, 2018 at 6:25 pm
    Hello all,
    I’ve got a BUNCH of 30fps footage, and I am trying to make it look like hyper lapse footatge. basically I just want to go in and take every 30th frame and delete all the stuff in between. is that something that can be done?
    -jon
    Jon Melot replied 8 years, 6 months ago 3 Members · 4 Replies
  • Eric Santiago
    March 20, 2018 at 6:38 pm
    Use time remapping.
  • Eric Santiago
    March 20, 2018 at 6:40 pm
    Oops I thought I was in After Effects forum.
  • Shane Ross
    March 20, 2018 at 6:48 pm
    add the clip to the timeline. RIght click on it and choose SPEED/DURATION…now adjust the speed to something like 400%…or 600%…until you get what speed up you are looking for.
    Shane
    Little Frog Post
  • Jon Melot
    March 20, 2018 at 6:53 pm
    That wa say first inclination, however, I think what I’m trying to do is more of a posterize… Speeding it up just speeds up all the frames. I want the abrupt change that happens from frame 1 to frame 31, not a really fast sampling of each frame. I’m currently trying to posterize the time to 1fps and then speed it up by 3000%.. see if that gets me any closer? Otherwise, I’m wondering If I need to export each video as a jpeg image sequence, then delete all the intermediary frees (That’d be a bummer of a workflow)
