Activity Forums Adobe After Effects Trying to Key better
  • Trying to Key better
    Posted by Martin Nowak on May 7, 2008 at 5:03 am
    I have a woman that was shot on green screen on DV and I have attempted to composite all the footage in AE 7 However Im still getting bits of the green screen through the tops of her hair, please, please help me solve this? Any advice?
    Im on a powermac g5, dual processor (NOT Intel)
    Marty N
    Pat Jaeger replied 18 years, 4 months ago 3 Members · 2 Replies
  • Kevin Camp
    May 7, 2008 at 6:00 am
    it would help to know how you went about keying.. which effects, techniques, etc…
    if it is just green spill, you might try the spill supressor effect…
    but, i can tell you that there is really no sure fired way to get a great key every time, but there are techniques that can help. there are tutorials here at the cow that can help.
    one is aharon rabinowtz’s supertight junk mattes, which is a techniques that will reduce the amount of area that you are keying and generally helps in createing better keys.
    barend onneweer has an older tutorial for precedural matte creation that is still a very solid way to produce a key using the concept of core and edge mattes.
    if you are using keylight, you can actually use 2 instances of the effect in a similar procedure to the technique that barend shows. the details are in the manual for keylight.
    i often use aharon’s super tight junk matte to ‘crop out’ the extra green screen area, then paste the masks back onto the layer to key, shrink it in (via the mask expansion setting) and maybe feather it a bit. then using keylight, set that mask as the ‘inside mask’ with in key light. this creates a core matte similar to barend’s and similar to the method outlined in keylight manual, but it render’s more quickly.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Pat Jaeger
    May 7, 2008 at 6:41 am
    Since you’re using dv, try applying an adjustment layer above your footage (before the key) with a gaussian blur of 4, then set the layers transfer mode to colour. This has helped me to get much nicer keys as it helps to clean up the jaggy edges of DV.
    Hopefully it will also help you,
    Pat jaeger
