Activity Forums Zaxwerks Trying To Keep Logo’s Colors After Importing
  • Trying To Keep Logo’s Colors After Importing
    Posted by Steve Framework on December 8, 2008 at 8:44 pm
    Hello everyone. I am fairly new to Zaxwerks and Illustrator.
    I’m simply trying to import my logo into Zaxwerks (3D Invigorator) with the original colors. I am able to import the logo successfully into After Effects, but the logo is completely grey and is missing all of its original colors after I import it.
    How can I import my logo into Zaxwerks and have it keep its original colors?
    Thanks for any help you can provide.
    Jon Okerstrom replied 17 years, 9 months ago 2 Members · 4 Replies
  • Jon Okerstrom
    December 9, 2008 at 12:03 am
    Steve,
    You need to check the box that allows you to use Illustrator colors. Keep in mind that blends and transparency effects won’t be carried through.
    Jon
  • Steve Framework
    December 9, 2008 at 1:47 am
    Well…I’ve been doing that and it’s still not working. And my logo doesn’t have any blends or transparencies. So I guess I’m still confused what I’m doing wrong.
  • Jon Okerstrom
    December 9, 2008 at 1:14 pm
    Hi Steve,
    Feel free to send me the file. jokerstrom1 (at) mac.com. I’ll take a look at it.
    Jon
  • Jon Okerstrom
    December 10, 2008 at 12:23 am
    Steve,
    The problem with the file was that all of the elements were grouped together. I ungrouped them and moved the different elements to different layers. Clicking “use Illustrator colors” when you import it should do the trick now. A couple of other thoughts – the logo is fairly complex and tight. You’ll want to use small bevels and probably negative edge offsets to avoid having the elements crowd each other.
    Hope this helps.
    Jonj
