Activity Forums VEGAS Pro Trying to install Ultimate S Pro demo
  • Trying to install Ultimate S Pro demo
    Posted by Ron Whitaker on August 24, 2012 at 6:31 pm
    I installed the Ultimate S Pro demo, but when I open SVP 11 64-bit, then click Tools > Extensions, Ultimate S doesn’t appear.
    I notice that the install script puts it in the Program Files(x86) folder under the VASST folder.
    Shouldn’t it be in the same folder as SVP 11, which is simply the Program Files folder?
    Thanks.
    John Rofrano replied 14 years ago 4 Members · 10 Replies
  • 10 Replies
  • Jeff Schroeder
    August 24, 2012 at 6:39 pm
    Mine is in the x86 folder and runs fine on SVP11-64bit
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • Ron Whitaker
    August 24, 2012 at 6:41 pm
    How did you install it?
    I go into SVP 11, and there’s nothing under Tools > Extensions.
  • John Rofrano
    August 24, 2012 at 6:42 pm
    [Ron Whitaker] “I installed the Ultimate S Pro demo, but when I open SVP 11 64-bit, then click Tools > Extensions, Ultimate S doesn’t appear.”
    That’s because it’s under:
    View | Extensions | Ultimate S Pro
    not the Tools menu. Anything with a GUI must go under View. If it’s under Tools it can’t have a user interface. The ReadMe file that displays after you install documents that you should look under the View menu.
    [Ron Whitaker] “I notice that the install script puts it in the Program Files(x86) folder under the VASST folder. Shouldn’t it be in the same folder as SVP 11, which is simply the Program Files folder?”
    No, the files in the VASST folder are other files that the Command Extension needs along with documentation, etc. The Command Extensions themselves are installed into a folder designated by Sony which (unfortunately) is hidden by Windows.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jeff Schroeder
    I guess the installer that VASST supplied. Have you restarted Vegas?
  • Ron Whitaker
    August 24, 2012 at 6:59 pm
    OK. Got it!
    It’s under View > Extensions, NOT Tools > Extensions!
    Thank you.
  • John Rofrano
    August 24, 2012 at 7:14 pm
    [Ron Whitaker] “OK. Got it! It’s under View > Extensions, NOT Tools > Extensions!”
    Cool. 🙂
    ~jr
  • Nigel O’neill
    August 25, 2012 at 12:19 am
    Ron
    I have added UltimateS buttons on the main tool bar, such as ‘cut to’ and ‘fade to’ cameras.
    I have noticed that the buttons sometimes disappear in 64 bit SVP in versions 10 and 11, but only when I use another application such as Excel or word for an extended period of time, say 10 minutes, and then return to SVP. The Ultimate S buttons are still there because if I hover the mouse, the tool tips appear and the still buttons work, but it is a bit of guess work as they have lost their icons. Restarting Vegas always restore the buttons.
    I have not reported it to Vasst as I consider it trivial, plus the fix is simple. SVP crashes often enough to restore the buttons anyway 🙂
  • John Rofrano
    August 25, 2012 at 4:09 am
    [Nigel O'Neill] “I have not reported it to Vasst as I consider it trivial, plus the fix is simple. SVP crashes often enough to restore the buttons anyway :-)”
    Actually this is well documented Vegas problem. We have no control over Vegas loosing icons and it’s not just our icons, it’s any script icons.
    ~jr
  • Nigel O’neill
    August 25, 2012 at 4:43 am
    Thanks John. I didn’t mean to imply Ultimate S was at fault. I am 100% certain SVP is at fault. I
  • John Rofrano
    August 25, 2012 at 1:14 pm
    No worries is it quite logical to blame a plug-in for it’s icon gone missing but in this case, it’s a well know issue with Vegas.
    ~jr
