Activity › Forums › Apple Final Cut Pro Legacy › trying to import xml file to fcp5
Posted by Rich Tru on September 1, 2009 at 1:43 pmcan anyone help, we have some footage on an external hardrive as xml. trying to import them into my fcp5, as i import under file import xml. I get ‘choose translation file’ and thats where it ends. some one said i could use log and capture as well – have tried that but it does see any device.
can anyone help.
urgent job!!!
Richard
Steve Eisen replied 17 years ago 3 Members · 5 Replies -
Tom Wolsky
September 1, 2009 at 1:49 pmWhat version of XML is this in? Sounds like it’s too new for the version of FCP you’re using. I think for v5 you need on more than XML 2 or 3. What did this come from?
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Rich Tru
September 1, 2009 at 1:54 pmI cant tell you exactly which version of xml, lets assume the version is too new, what can i do?
Steve Eisen
September 1, 2009 at 2:21 pmXML footage is not natively supported in FCP. Importing the XML files will not work in FCP. Is this P2 footage? If yes, you can import the footage if you have installed the proper driver.
What you can do is import and export your Final Cut Project File as XML. This is what you are trying to do with your footage. As you can see, it does not work that way.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Rich Tru
September 1, 2009 at 2:32 pmThanks i do understand that, my understanding is that they are not P2 files
heres what i got:
files in xml
files in mxfnone of which i can import.
trying to open the mxf files in xdcam transfer for conversion and wont accepts these, 0files, usually i have an icon pic of the files in mxf.any solutions will be welcome
Steve Eisen
September 1, 2009 at 2:51 pmYou need to find out what camera created the MXF files. It is possible that you will need a newer version of FCP in order to work with the footage.
MXF files are not natively supported in FCP either. With third party plug-ins, you can work with the MXF files.
Steve Eisen
Board of Directors
