Activity › Forums › Adobe Encore DVD › Trying to import an After Effects comp as a menu.
  • Trying to import an After Effects comp as a menu.
    Posted by Jon Henry on September 22, 2010 at 4:11 pm
    Hey team,
    I have made a motion menu in After Effects. Whenever I “dynamic link” it into encore, is show up as an Aftrer Effects composition, but I can’t make it into a menu. I have made custom buttons in the comp, but the comps aren’t showing me any layers.
    Am I missing a step? I have the ae comp in encore, and need to make it act like a menu, with all the butons etc.
    Any ideas?
    Ian
    Clint Milner replied 16 years ago 2 Members · 3 Replies
  • Clint Milner
    September 23, 2010 at 10:38 am
    Hi Ian,
    You need to assign the AE project as a Video asset of your menu under the Motion Tab of your Menu Properties.
    Alternatively you can click on a blank menu in Encore, Menu –> Create After Effects Comp (which does the above for you and launches AE) and then import your comp that you’ve already made in AE.
    Hope this helps.
    Clint
    Adobe CS4 Master Suite
    Vista Ultimate 64 SP1
    Intel Core i7 920 @ 3.60GHz
    12 GB DDR3 RAM
    NVidia Quadro FX 3700
    Matrox RT.X2 LE Capture Card
    4 TB RAID 5
  • Jon Henry
    September 23, 2010 at 4:02 pm
    Thanks for your suggestion.
    I now have the comp in Encore, it is a menu…but the buttons I’ve designated (with the (+)) and their respective subpicture highlights are not functioning at all. In the layers panel, it all shows up as one layer “background”.
    I’m absolutely baffled.
    Ian
  • Clint Milner
    September 24, 2010 at 2:24 pm
    1118_menutest.zip
    Here’s a sample project and screenshot to show you the way I did it.
    Hope that helps.
    Clint
    12 GB DDR3 RAM
    4 TB RAID 5
