Activity Forums VEGAS Pro Trying to get markers to return to main menu
  • Trying to get markers to return to main menu
    Posted by Rick Rintala on May 1, 2009 at 2:33 am
    Ive created a scene selection menu with multiple chapters. When I select a chapter, what do I need to do to make it return to the selection menu after the chapter is played, rather than just play the following chapters?
    Rick
    Rick Rintala
    Flying Finn Video Services
    Bedford Texas
    http://www.flyingfinnvideo.com
    Mike Kujbida replied 17 years, 4 months ago 4 Members · 5 Replies
  • Dave Morris
    May 1, 2009 at 2:04 pm
    I think what you’re looking for is “End Action”. Set the Command to LINK and the Destination to your main menu.
    (By the way, I’m just down the street from you!)
    Dave Morris
    Producer
    Air-Wave Productions
    (aerial travel adventure videos in HD)
  • Dave Morris
    May 2, 2009 at 3:54 pm
    First of all, I am presuming that you use DVD Architect, which allows you to create a scene selection menu, and that you have each menu item set up to play from a particular marker. You should then be able to set the End Action for that menu item to return to the menu rather than continuing to play through the end of the video.
    Dave Morris
    Producer
  • Rob Strobbe
    May 2, 2009 at 3:57 pm
    Check the manual / online help for “Adding a Scene Selection Menu” and then the subsection about one that returns to the scene selection menu after each chapter.
    Essentially, what you’re going to do is add the same movie to the project multiple times and change the In / Out point for each copy. That will turn each chapter into a full-fledged media item. And DVD Architect will reference the same file for each copy, so you don’t have to worry about it using extra space.
    Rob
  • Rick Rintala
    May 2, 2009 at 3:59 pm
    Dave,
    I dont think thats what im looking for. Unless you know a way to set end action on individual chapter markers in a video. I only know how to do that to an entire video file. Im doing weddings and home movie transfers. When i have a multiple chapter scene selection, say 10 for example, i need to know if there is a way to select one chapter of that scene selection and when it hits the chapter marker for the next chapter it goes back to the selection menu, instead of just play all subsuquent chapters in that media file. Is there a way to do that? Would I need to render all chapter as individual files to do that?
    Rick
    Rick Rintala
    Bedford Texas
  • Mike Kujbida
    May 2, 2009 at 7:09 pm
    Rick, to expand on Rob’s suggestion, have a look at my response in the DVD scene selection markers as in comm. DVDs thread.
    I go into great detail about the steps involved in doing this.
