Activity › Forums › Adobe After Effects Expressions › Trying to get a lower third template working
  • Trying to get a lower third template working
    Posted by Richard Pizey on February 1, 2021 at 4:22 pm
    Hi all,
    I’m trying to get a lower third template working but not having much luck.
    I have three lines of information, and I’d like my rectangle to change size depending on which field is longer.
    I’ve gotten pretty close with the following expression:
    a = thisComp.layer(“Name”).sourceRectAtTime(0).width+98
    b = thisComp.layer(“Job Title”).sourceRectAtTime(0).width+98
    c = thisComp.layer(“Company Name Further Information”).sourceRectAtTime(0).width+98
    if (a>(b||c)){
    x=a;
    y=7.5;
    [x,y]
    }else{
    x=Math.max(b,c);
    y=7.5;
    [x,y]}
    but it just doesn’t seem to quite work. It seems to only recognise the input of the “name” or “job title” fields.
    I’ve been trying to figure out what I might be missing here, any help massively appreciated!
    Richard Pizey replied 5 years, 7 months ago 2 Members · 3 Replies
  • Kevin Camp
    February 1, 2021 at 4:30 pm
    You are soo close. You won’t need the if statements, just put a Math.max() inside the Math.max():
    x = Math.max( a, Match.max( b, c ) ) ;
  • Kevin Camp
    February 1, 2021 at 4:34 pm
    Actually it looks like you can now have multiple arguments inside Math.max. This works for me:
    x = Math.max( a, b, c ) ;
    I always thought it should work that way : )
  • Richard Pizey
    February 1, 2021 at 4:35 pm
    Kevin, you sir are a scholar and a gentleman.
    I thought I was probably overcomplicating it!
    thanks so much
