Activity › Forums › VEGAS Pro › Trying to get 1:50 on a DVD with Vegas
  • Trying to get 1:50 on a DVD with Vegas
    Posted by Rick Rintala on March 13, 2008 at 1:04 pm
    I am trying to get 1 hour and 50 minutes of rendered video on a DVD. The prepared file is 5.4 gig. When i try to burn a disc it tells me mile file size is too large. Do I need to adjust the bitrate to get it to a file size that will fit? Any reccomendations would be greatly appreciated.
    Rick Rintala
    Flying Finn Video Services
    Bedford Texas
    http://www.flyingfinnvideo.com
    Mike Kujbida replied 18 years, 6 months ago 2 Members · 3 Replies
  • Mike Kujbida
    March 13, 2008 at 1:46 pm
    The maximum (audio & video) file size for a single layer DVD can’t exceed 4.3 gigs so yes, you do need to adjust the bitrate when rendering from Vegas.
    My bitrate calculator gives the following settings. This assumes AC-3 audio.
    CBR: 5,000,000
    VBR: 8,000,000 / 5,000,000 / 3,000,000
    (Max. / Avg. / Min.)
    Here’s a link to an online calculator on the VideoHelp site.
    Here’s a link to Edward’s newsletter detailing the DVD authoring process.
    Here’s a link to the bitrate calculator I use.
    Note that this links to a zipped file.
    Check my responses in the Correct Bitrate settings in Vegas for DVD Architect thread for the settings I recommend and why I do so.
  • Rick Rintala
    March 13, 2008 at 8:39 pm
    Mike,
    Thanks for the advice. One question. In your exp, how low can you go on bitrate before you start loosing video quality?
    Rick Rintala
    Bedford Texas
  • Mike Kujbida
    March 13, 2008 at 9:58 pm
    Rick, I personally don’t go below 4,000,000 either as a CBR value or as Average for VBR.
    Depending on the quality your source material, this may need to be even higher.
    My usual recommendation is to burn a short segment (just a few minutes) at the intended setting to an RW and see what it looks like on a TV.
    That method, better than anything else, will tell you right away if it’s too low.
