Activity › Forums › Adobe After Effects Expressions › Trying to follow a tutorial, but stuck on expression
  • Trying to follow a tutorial, but stuck on expression
    Posted by Adam Dorsz on February 17, 2019 at 9:17 pm
    I’m trying to create a 3D audio visualizer in AAF and I’m stuck on an expression error.
    In the tutorial that I am following at around 1m30s, the guy copies an expression and inserts it into the position of a solid. I wrote down the expression and checked that it matches, but when I paste it in I get the ‘expression result must be of dimension 2, not 1’ error. I don’t know anything about expressions and I have no idea what I’m doing wrong. Would be great if someone could help me out.
    Thank you!
    https://youtu.be/yklQsJB9rcY?t=91
    myEndTime = 0;
    thisTime = time-thisLayer.inPoint;
    segMin = 0.8; //minimum segment duration
    segMax = 0.8; //maximum segment duration
    minVal =[0.0];
    maxVal =[10.99,6.99];
    end = 0;
    j = 0;
    if (thisTime >= myEndTime) t = thisTime else t= myEndTime;
    while (t>=end){
    j+=1;
    seedRandom(j,true);
    start = end;
    end += random(segMin,segMax);
    endVal = random(minVal,maxVal);
    seedRandom(j-1,true);
    dummy = random();
    startVal = random(minVal,maxVal);
    [Math.floor(startVal[0]), Math.floor(startVal[1])]*150+[40,40];
    Adam Dorsz replied 7 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 17, 2019 at 9:40 pm
    I think to get it to work, you just need to add a semicolon to this line:
    like this:
    if (thisTime >= myEndTime) t = thisTime; else t= myEndTime;
    Dan
  • Adam Dorsz
    February 17, 2019 at 9:58 pm
    That works, thank you sir!
