Activity › Forums › Adobe After Effects › Trying to figure out a particular transition
  • Trying to figure out a particular transition
    Posted by Mark Pirres on November 5, 2014 at 5:31 pm
    Hello,
    I’m trying to figure out the technique used in the following video https://vimeo.com/77127939 at:
    – 00:25: there’s a cross fade but the clips seems to brighten up too?
    – 00:35: is it a flare coming through from below? or a light built in after effect? (which sort?)
    I have thought both the above might have been the results of some light source coming in during the actual shooting, but I still think it’s an added effect – am I wrong?
    thanks
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    George Goodman replied 11 years, 10 months ago 2 Members · 3 Replies
  • George Goodman
    November 5, 2014 at 9:12 pm
    First is a fade through white and the second looks like maybe a little film burn overlay with a cut in the middle. I bet you’d like film burns even though they’re a liiiiiiitle bit different.
    This video has 5 free ones:
    https://www.youtube.com/watch?v=9C_KYtEaN98
    “|_ (°_0) _|”
    Sincerely,
    George
    http://www.vimeo.com/georgegoodman
    http://www.linkedin.com/in/georgefranklingoodman
  • Mark Pirres
    November 6, 2014 at 11:31 am
    Thanks both for this, although Dave I think you misunderstood the second transition (maybe there was a lag with the playback): I meant the shot where there is a table with a vase of flowers on it and then it changes to a field with a tent on the back.
    George I’m not 100% sure is a film burn though (I meant to write film burn in my first post instead of flare); it seems to come up from the lower part of the frame in a very steady way, while film burns seem to flicker quite a lot. You would rule out a light was created in After Effects (or similar) then?
  • George Goodman
    November 6, 2014 at 9:53 pm
    Ya, that second transition probably isn’t a film burn, just similar.
    There are a lot of ways to do the second one. You could use a solid or shape layer that is a pale yellow move it downward so its about halfway covering the bottom of the frame, add a blur, change the blend mode to overlay, add or multiply (play to see what you like) and fade in and out the opacity and cut the video in the middle.
    “|_ (°_0) _|”
    Sincerely,
    George
